no boost
Hey guys,
My 951 has been down for a while over winter because the gaskets on the wastegate had burned through. So I got the new ones reassembled everything and now I have no boost. The car runs good -13psi at idle then when you hit the gas you can hear the turbo start to spool and it jumps from -13psi to 0 psi. Any sugestions on what the problem is??
Thanks all for any help
