Timing/balance belts cover
How does one get access to the two lower 10mm bolts that are near the power steering pump? They very difficult for me to access to remove. What am I missing? Thanks in advance.
This one need's time - most things on these car need's time...
First of all do it carefull - after setting the tool on the bolt I use the left hand to tight/untight
mostly not looking - that's the way I do it - more than once
1/4" socket wrench, 2" extension, 10mm socket. I think from above is easier. With the IC pipes and airbox removed, it should be easy.
