Alternator ducting
Alternator ducting
Reinstalled a duralast alternator to replace my dead OE alternator. Noticed a couple things:
1. There is a slightly different configuration for the posts for the wiring, mostly that there is a black plastic guard-like piece near the posts on the back of the alternator, causing some difficulty in securing down the wiring at the correct angle for reinstalling the rear cooling duct.
2. Cooling duct - since plastic piece near the posts in #1 above is in the way, duct won't mount back up. Also, the studs for mounting the duct are MUCH shorter than the OE and I'm not sure I can even get some threads to secure it.
So, next steps are to remove alternator, see about getting rid of that plastic piece around the posts, and test fit the cooling duct while it's out.
Did a search, and many seem to suggest the cooling ducting is absolutely necessary for good alternator life, while there have also been cases of decent life without the ducting. Mine didn't have the hose, so the rear duct was basically shielding from oil/debris, and not offering much cooling.
Would a more current reman'd alternator still require the cooling? If so, source for a less deep rear duct?
Thanks.
Thanks.
1 Post
IMHO return your duralast alternator and buy a reman Bosch.
Also ducting is important for long alternator life. In fact go to a VW store and get the rigid tube they use for their heaters and use it for the cooling tube to the back of the alternator duct. It is cheap and makes your alternator happy.
