Help identify heatshield part
Can anyone help identify where this heatshield mounts to? I think it goes near the turbo on the driver side but can't remember exactly where. Thanks in advance.
The main one pictured goes at the back of the oil pan along the gasket, right behind where the header meets the cross-over. But it looks like another shield behind that piece or connected to it?
UAE Rennlist Ambassador
That goes on the driver side, it is the AOS heat shield also the the intake manifold rear support bracket attached to it, as well as the downpipe block mounting bolt.
There is a different heatshield for the AOS. I have that installed already. This is a different smaller shield. Does anyone have a picture of where this goes? Help!
Here is a picture I found on PET that looks like the shield you have posted. I guess I was off, but that does look very similar to the shield found on the pass. side but without that flap that is on yours.
But that still goes on the driver's side of the oil pan/balance shaft/AOS area.
