sparatic boost
***so im tired of writing these posts. and im sure ur all tired of reading them, ![typing](https://rennlist.com/forums/graemlins/yltype.gif)
***so when i drive my loves to boost to full .75 bar or the 11psi its supposed to be at. but only sometimes, there other 50% of the time my car wont push anything near past the atmosperic level. say .25bar. it just will not build boost no matter how hard i press on the gas at WOT.![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
***BUT.....if i turn off the car then start it again it will build full boost no prob.![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
***sometimes it will build full boost all day. sometimes it will build it 2 or 3 times then crap out on boost building when im trying to pass a big semi or something.![nono](https://rennlist.com/forums/graemlins/nono.gif)
***what could it be. i just got new rod berrings and crank berrings done. so there motor is pretty refurbished.
***car and motor are completly stock. no exhaust(yet) no MAF, no chips. no nothing.
**my timed valve is no more than 4 months old.
**my guess is either a ****ty WG or my DME/KLR are crap.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
PLEASEEE!!!
ANY help or ideas in the right direction would be great. this is just annoying the **** out of me now,![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
thanx guys
PLEASEEE!!!
thanx guys
Hey DasBOOST,
Had exactly the same thing happen to me years ago. Tried everything, including the first thing everyone tells you - check the Throttle Postion Sensor/Switch.
I'm an Electronics Eng by trade so no problem testing it thoroughly, but no fault found.
A year later & much monitoring of the DME/KLR, I though what the hell, bought a new TPS and lo & behold no more boost cuts ! Couldn't measure any difference with a DVM between new one & my old one, but it worked so..
Try it first !
Try it first !
