Help with stripping interior tar paper-like coating
I'll post finished pics in a month or so if I ever get this done....and if my fingers still work then from all the scraping.
This is when I thought, "yeah no problem I can do this"
![](http://inlinethumb62.webshots.com/14461/2538187590058304719S500x500Q85.jpg)
Here I'm becoming a little concerned that the 5 gallons of adhesive remover I bought may not be enough.
![](http://inlinethumb29.webshots.com/39452/2386400950058304719S500x500Q85.jpg)
And right here is the exact moment I said outloud, "What the hell did I get myself into". Everything is glued in this car...everything and everywhere.![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
![](http://inlinethumb53.webshots.com/34356/2308214670058304719S500x500Q85.jpg)
My preferred method is a good heatgun, a set of metal scrapers in various widths, and a "crud thug." If you plan to repaint the tub anyway, the crud thug is perfect for removing the remaining adhesive under the tar. I've done an entire car in a few hours with no chemicals.
![](http://toolmonger.com/wp-content/uploads/2006/06/post-crudthug.jpg)
The alcantara was done by Rob (Budd?) and I cut it down and made it a "shorty" dash and rapped the excess material around. Center vents are still functional with fresh air as is defrost. Despite the stock HVAC being removed. Side vents are dummies.
bought a propane torch tonight and used it...still not close to done BUT what a world of difference!
torch for 10 seconds then scrape....repeat
where can i get a crud thug for all the adhesive crap?...nevermind I found it and man that thing is pricey at $400+
might just try a grind with an attahment (imitation crud thug)
how did you guys get the floor clean enough to paint? I thought about getting mine sandblasted and painted eventually.
