Phase one of my project
Ive been ordering parts on and off the last couple months and now finally have everything together to start phase one of this cars build. Im planning to start tearing everything down wednesday afternoon and hopefully will have it all back together by friday night.
The details..
LR Stage 1 cylinder head, o-ringed deck
Widefire headgasket
LR steam vent kit
LR black **** boost controller
Cycling valve delete
EGT probes on each exhaust runner (its all apart..i figure why not
New heater control valve
Tial 38mm wastegate
Replace rubber lines for the ISV and brake booster
Install IceShark battery cables and headlight harness
Install Transpo voltage regulator
Custom fuel jumper line (damper to rail) using Aeroquip hose and Push-Lok fittings
and 5lbs of silicone vacuum hose / lines..
Im also planning on removing the metal pipes under the intake and simply running one 19mm silicone hose from the AOS to the intake boot.
Wednesday i need to get the EGT bungs welded onto the spare set of exhaust manifolds i have..and still need to get the bung welded on for the wideband. I am going to leave the EGT bungs plugged for the time being until i get an EGT gauge. I only plan on monitor the 4th runner..but may eventually go for one of those 4-channel aerospace gauges to do all four at the same time.
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201988%20Porsche%20944%20Turbo/IMG_5912.jpg)
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201988%20Porsche%20944%20Turbo/IMG_5911.jpg)
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201988%20Porsche%20944%20Turbo/IMG_5913.jpg)
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201988%20Porsche%20944%20Turbo/IMG_5917.jpg)
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201988%20Porsche%20944%20Turbo/IMG_5914.jpg)
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201988%20Porsche%20944%20Turbo/IMG_5957.jpg)
Ive done the headgasket before on my n/a, so i dont expect it to be much different on this car. I think the most time is going to be spent cleaning and routing all the new lines / hoses (both vacuum and battery). Im really not looking forward to removing the cam tower. Ive removed them a couple times now, and every time i felt like the allen head bolts were about to snap off before they finally came loose. Other than that, the usual two allen head bolts for the water jacket on the cylinder head hopefully wont give me any issues either.
The car is running great right now, just turned 107k on the clock. Though the broken exhaust stud on the #2 runner is killing spool up. I figure now is as good a time as any to fix that and bullet proof the top end. I figure the o-ringed head will be more than suitable running 15psi (i dont plan to exceed this really). The car still has APE Stage 2 chips..and im probably going to take them out and go back to stock for the time being..then a few weeks down the line go with a set of Vitesse chips for the 26/6.
The details..
Widefire headgasket
LR steam vent kit
Tial 38mm wastegate
I did the same thing running 3/4 inch silicone tubing from the AOS to the j-boot. Have had no issues so far! Good luck! I pretty much did the same things to my car (minus the stage 1 head...). Good luck!
-Darwin
FYI: the nipple on top of your original wastegate will thread into the intercooler pipe. An easy way to get rid of the banjo bolt there if you don't like it.
-Darwin
Darwin, i have Laust's vacuum manifold but its a single port and i have a dual port intake manifold (late '88). I am going to try and plug one of the two ports so i can use the manifold still, i may also be able to stack the manifold on the end of a longer banjo bolt also. Hopefully i can get one combination to work.
On my '87 n/a, those two allen head bolts holding the water jacket flange down came out pretty easily. They were practically finger tight. I was dreading removing those also! Hopefully its the same case this time around!!!
Does installing the exhaust temp probes right on the manifold throw off the resonance at all? From what I understand there is quite a bit of engineering that went into the factory exhaust manifold?
Jon im doing the same thing with my car now, i already got my widefire hg, water oil gasket,rear cam ower gasket, new rubber cam tower gasket from lr, and a new catchcan for the oil. I got the cam tower off so far and just waiting for it to get warmer to finish up. Let me know how yours comes out.....need any help just give me a call..... -Adrian
Ironically the generic type 19mm hose in 45* and 90* bends is twice the price as the Samco equivalent. Beats me as to why.
