flywheel weight reduction
You women drivers want all that ultra smooth easy driving stuff, go get a luxo mobile with an automatic and that oh so responsive torque converter.
When I got my car it had a lightened knife edge crank, lighter pauter rods, factory pistons and ALUMINUM flywheel. I never had any problems rolling off in 1st gear...even on hills. Just rev it up and go, it's a sports car. The only thing I had to adjust too was shifting quicker to match rpms because it reved down quicker on the shift lift. But hey, I LIKED that!
Same on the 2.8 with the exception of a stage 4 composite solid puck clutch. It made it a little challenging at first to keep it from bucking a little as it engaged, but that was just because the engagement on the pedal was only about 1/16 of an inch of travel. Never killed the motor as the "lack of inertia" theories suggest. Heck, it even idled smooth at 840 rpm with the A/C on.
The tq thing with the stock fly has always done my head in a bit. The heavier the mass is, the more tq is needed to get it to move, but once it's up and running then wouldn't it generate it's own torque through the heavier recirculating movement? My logic is patchy at best, granted...
The pressure plate is also a big mass, so the combined weight of the flywheel and pressure plate is probably 30+ lbs. We are talking about taking 5-8 lbs off the flywheel, which is really only reducing the flywheel/PP assy by approx 20%. So, although its noticeable, its not a huge change to the overall inertia. And I agree with RKD, that a lightweight flywheel in a 944 should not cause much driveability issues.
Some of the cars with dual mass flywheels, 964s in particular, have more issues with 1st gear stalling when using a LWF, because the dual mass flywheel is something around 30 lbs, and the factory Carrera RS/Cup single mass flywheel is 5-10 lbs - so they are dropping around 20 lbs, which is a more dramatic change.
