Power Perfect users...
..have a question regarding wiring the controller into the harness. Lindsey's supplied diagram shows the ground wire from the controller plug connected to the DME #6, which runs to the MAF set-up (pin #2 on the vain & pin #3 on the MAF plug). The rest of the diagram looks fine to me, just questioning why this "plug ground" is tied into the the MAF plug this way.
Thanks for your help!!
BTW - tried downloading the diagram for show and tell, but couldn't open up the file on Lindsey's site??
Just make sure you have the in and out wires hooked up right. And I guess #6 is a ground thats why they said hook it up there. Send me a pm wen you figure out everything. I about about to tune mine and could use the help.
