Dissolving loc tite?
The po of my car installed some of the head studs right over globs of loctite like a moron. How can i remove it so the new studs will go in nice? Is there any chemical i can pour over it to dissolve it?
Interesting question, here is what I found. I use brake cleaner when it is wet, never tried to remove it after it has hardened.
REMOVAL/CLEAN UP
Q: What solvents can I use to remove liquid Loctite materials?
A: Most organic solvents are effective in removing anaerobic adhesives. Chlorinated solvents are most commonly used.
Q: How can I remove a fastener that is "permanently" locked in?
A: The application of heat is needed to remove a fastener that can't be removed with a hand tool. A temperature of 325F and above is needed to break down a standard anaerobic, 500F for high temperature Anaerobics. A heat gun or propane torch is commonly used to do this process, and careful disassembly should occur while parts are still hot. Once apart, and cooled, use methylene chloride (Chisel #79040) to remove cured excess material. Always wipe down the fasteners with clean up solvent to remove the wax film that Chisel leaves on the surface.
http://www.ccmotorcycles.com/24205/Threadlocker242.htm
REMOVAL/CLEAN UP
