Tear it down??
Tear it down??
When I depress the clutch I hear a little grinding? Chatter?
but only before the clutch hits the floor not at the top only near the bottom??
It will go into gear no problem it just grinds chatters when engaged.
New clutch install... everything is brand new. KEP stage 1, 6 puck spring loaded disk, FF Wheel, Clutch fork, PB, TOB...
Do I keep bleeding it??? Or tear it back down???
thanks in advance,
-BB
thanks in advance,
-BB
Perhaps it's over-extending and the fork is bumping into the PP?
I have a centerforce "dual friction" clutch setup. If the clutch pedal isn't adjusted properly it will make a grinding sound as the fork is bumping into the weights on the PP.
What I'm saying is: wiggle into the driver's footwell and adjust the clutch pedal before you tear the whole thing apart again.
