fuel guage problems
I cant seem to find the problem the guage, always full. When I remove the connection from the tank the guage drops to zero. I cleaned the contacts but it will still reads full when reconnected. Mine is an 87 (951) any advice???
Could I have also lost a ground some where?
If so where would I find it. I know in the 87+ the ground is under the dash I just dont know where to look.
I will also check the sending unit.
IIRC full ground is when the tank is full, then using a variable resistor in the sending unit, tha gauge drops as fuel level drops. This is why the gauge drops after you lose the ground/unplug the connector. I am speaking generaly on modern vehicles, Pcars should not be too different.
