Rear Suspension Upgrade To Coilovers/ Lowering Springs
When I rebuild my car over the summer I want to upgrade the suspension. My rear suspension has the torsion bars and I would like to update it to coilovers. Will this just bolt up or does it require special tools and custom fitting. Did the turbos come with coilovers in the rear? Where is the CHEAPEST place to buy coilovers and lowering springs?
Ground Control
http://www.ground-control-store.com/.../II=749/CA=159
Or were you looking for a particular brand? If so, it might help to tell us what you are looking for.
To answer your question, the turbo's also have torsion bars. Why do you want replace the torsion bars?
Herr Unmöglich
Your second question should have been your first.
If you have high mileage, for sure the shocks will help. You may find there is no reason to spring for coilovers which will run you $1000 more than just rear shocks.
Depends on your goals.
Replacing the t-bars won't have any effect on the body sway really. You can go to stiffer t-bars of course. What about your sway bars, what ones do you have on the car now? Do you have the stock suspension on the car now and just want to make it corner flatter? That's easy enough without taking out the t-bars. Unless you want to change over the rear coils on a regular basis because you race at a whole bunch of different tracks and have recorded what springs suit which course, then what you want to do is overkill. Look at the pics of my car in the thread on the front page now titled 'Pictures of the car at speed'. This is pushing through an off camber corner hard in 3rd gear. Doesn't look like it does it. I've got stock t-bars in my car. You can upgrade your suspension to handle very well without taking out the t-bars IMHO.
The car has the original struts in the rear and the stock sway bar. What company of shocks works the best for the money? Will a front strut brace help a lot?
I am still not clear what you are looking for.
I agree with Patrick, there is no structural advantage to coil-overs over T-Bars. A spring rate is a spring rate
Rear coilovers have the main advantage that it is easier to adjust height, so makes the job of corner balancing easier. Corner balance is one of the major factors in understeer/oversteer and turn-in behaviour.
Along with that there is a bigger range of spring rates that you could use, because there is a wider choice in coil-over springs than in T-bars.
Body roll is best reduced with sway bars. If you feel you have got to much body roll rear (how do you know?) a thicker sway bar will help. Too stiff and you will increase oversteer.
A strut brace will stiffen up the front end, and keep the camber more constant wile cornering, and as such improve the front grip.
All new shocks are better than old worn shocks. Koni and Bilstein work fine on Porsches, as I am sure many others will too
There is so much info using 'search' to find all sort of opinions as what is the best upgrade suspension package out there. Not sure what's the cheapest though?
So if you keep the torsion bars in the rear and run a coil over setup, how much of a spring rate would you suggest running for the track? Let's say I was to get 250lbs rear springs, that would bring the grand total of the rear to what?
this link will get you started, but be warned you have hours of research to do and a lot of opinions (all valid) to sift through when looking at suspension modifications.
http://www.asco96.dsl.pipex.com/944t/suspension.htm
There's a formula you need to use for figure out the combined rates of the springs and t-bar to arrive at your effective wheel rate in lb/in. I'll dig it up from when Karl from Racers Edge figured out mine.
Just changed my susp to 250# Welt springs in front, 27mm tbars rear (220#), so should be pretty balanced and comfortable on street w/ a decent upgrade from stock for DE. I also run Koni yellows all-around. I'll have to play with the rebound settings some as I'm getting used to this car. I'm also installing a 22mm Welt adjustable rear swaybar and a M030 30mm hollow front swaybar, hopefully receiving from Paragon this week :-)
Changing the tbars was a pretty big job. Definitely helped to have a 911 guy helping me index the new bars. It is possible to get about 1" of rear height adjustment using the eccentric bolt on the spring plate.
