FS 16v turbo conversion parts
Hi Folks,
cross post from S2 forum
Some of you may recall I built a high compression, mid boost turbo some time back on my 944S2 cabrio. I spent a lot of time and effort on the custom parts needed to do this. The results were beyond my expectations, awesome & the aesthetics look factory.
Since then I am part way through a phase two rebuild with a significant amount of power in mind 600+HP, I'm a greedy horsepower junkie I know, so this will mean substantially upgrading all my original parts.
So here is a short cut for those who wish to convert the 3.0 16v to a turbo, all the hard work done. The original goal was 400HP and this kit of parts will help achieve that.
16v turbo inlet manifold
951 throttle body rebuilt
larger alloy inter cooler pipes custom built
3" alloy inlet to turbo
Porsche by pass valve
By pass tubing and clamps
55lb flow matched flow 12 ohm injectors (4 months use)
all silicon hoses & clamps
In the picture attached the items included are marked with an "x", did'nt mark the 4 x injectors
U.S$850 plus postage - to the U.S will be about $60, local in Aust around $15
I don't wish to split the package.
regards
mike
regards
mike
Dillon I cant say as I havent got any experience with the 2.5 16V...I had a look on PET but couldnt find any info that would help.
Raven its still for sale
