m030 questions
Hi, as I understand, the m030 option on our cars means a 19mm balljoint, and new bigger rotors/calipers, is that it or something else?
I'm also aware of the m030 suspension/shock difference, but I allready have 2way KW comp.
since I'm not gonna use the brakes anyway, can I just machine a regular 87+ hub for a 19mm joint and be done? or does it have some extra magic?
The balljoint is not changed in M030.
The brakes are really a Turbo S 88 and 89-91 change since they are used even on the non M030 90-91 models.
The brakes have different (radial) mounting so the hubs are different between the 220 hp and 250 hp models.
The M030 control arm does have a different part number to the non-M030 control arms. I had assumed (but am not sure) that this was due to a different ball joint to be able to cope with the height adjustable Koni struts - what's the point in having them if you cannot use them due to the well documented ball joint failure problems with lowered cars.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
so if going charlie arms, all uniballs, etc. m030 hubs/spindles doesn't really offer anything of a regular 87+ in strength? it's gotto handle 295's on 18x11 up front.
