Fuse box surgery
Fuse box surgery
I'm transplanting ABS into a non-ABS body.
There is a main power line on the harness that terminates on the fuse panel. Problem is, how to add the new line to the panel without having the factory fuse bus pins etc. I had a look at stealing a pin from an old fuse panel, but the pins are not really designed to be removed and reused [shocker!].
Anyone BTDT?? All clues gratefully received
Not that bad, really. Had a nasty wall impact that nearly destroyed the original body. Had a rear wheel bearing collapse, and the rest was just a passenger ride.
Moving the drive line & suspension [& roll cage, fuel lines, brake lines, ABS system, and countless other little things] looked like a better proposition than trying to pull the original body back into spec, plus all the related body work. I seriously neglected the first law of race cars - every component of a race car involves fabrication.
The hard work is done. All that's left is the mountain of detail work like this fuse box issue.
are you talking the main power line for the pump or a relay that kicks on the pump? the main pump likely needs to be a heavy line like a stereo amp line. I would potentially just use small distribution box designed for powering a stereo amp. that way you can mount a clean 50amp fuse or whatever is spec.
