Main weaknesses in the 944 turbo engine?
#46
I think that's good advice Dan. Having a much larger choice for the future can only be good. I also agree that you can probably run a good motor on 15psi reliably. What are the restrictions to the sump or oiling in those classes if any?
#47
http://www.usnicom.com/
These folks did my 3.0 block. Many 951, 928, and 911 motors running with this solution with very good results.
#48
What is the real final cost of NiCom plating? The pricing on the "sheet" is just the process, which doesn't include taking every pc of steel out of the block, every one before the process of dipping the block for etching.
