Tie-Rod Removal Tool
Old 02-11-2008, 11:51 AM
Kool
Part of the IN Crowd
Kool's Avatar
Default Tie-Rod Removal Tool
I have tried to pull my tie rods off of my spindle assembly and after 20+ years they do not want to budge. What tools do you guys use to pop these things apart? I don't want to ruin them I have a tie rod tool but it doesn't want to stay on long oenough to pop it off.
Any help would be greatly appreciated.
Old 02-11-2008, 12:27 PM
Spidey944
Spidey944's Avatar
This is pretty simple if you do it right. Get a nice big hammer, a few pounds will do, and hit the spindle, not the tie rod, right where the tie rod drops through the spindle. Give it a few good whacks to loosen the rust and crap. Then it should come right out. Sometimes all you need is a little persuasion!
Old 02-11-2008, 12:31 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
There is a special tie rod removal tool out there, its universal and it works.........
Kool
Kool's Avatar
I will have to try that again. Maybe I need a bigger persuader.
Old 02-11-2008, 01:00 PM
Techno Duck
Techno Duck's Avatar
Pickle fork if you dont care about saving the tie rod ends. Otherwise PepBoys and most auto stores have a universal tie rod removal tool that works great. See picture below..
Old 02-11-2008, 04:45 PM
TRP951
TRP951's Avatar
heres mine
Old 02-11-2008, 04:55 PM
schwank
Herr Unmöglich
schwank's Avatar
I used a big *** pickle fork and a BFH.
Old 02-11-2008, 06:40 PM
hosrom_951
hosrom_951's Avatar
Pickle Forks will damage the boots.
I used this for the tie rods and ball joins for both our BMW and Porsche:
Old 02-11-2008, 07:14 PM
schwank
Herr Unmöglich
schwank's Avatar
Hussam is right... the boots did get a little nicked up. Not too bad though, I'd reuse them if I had to... but I don't as I'll be swapping this power rack to early tie rods.
Old 02-11-2008, 07:18 PM
Luis de Prat
Luis de Prat's Avatar
I replaced the boots along with the tie rods, so no problem there.
No amount of hammering would get mine out, but the pickle fork worked like a charm for me.
Old 02-11-2008, 11:33 PM
Tom M'Guinn
Tom M'Guinn's Avatar
I used exactly the same puller, bought at Kragen's if I recall. Worked like a charm. Hitting the spindle didn't work for me on 20 year tie-rods.
Old 02-11-2008, 11:38 PM
The DareDevil
The DareDevil's Avatar
Works every time.
Old 02-12-2008, 12:41 AM
FRporscheman
FRporscheman's Avatar
+1 pickle fork. One time I couldn't find my pickle fork so I tried using a monkey wrench as a pickle fork and that actually worked well for me.
Old 02-12-2008, 02:02 AM
sayporsha
sayporsha's Avatar
I've been using one like this for years. I put a penny between the tool and the shaft end to protect the threads. It takes a lot of pressure and they usually come loose with a bang.
Old 02-12-2008, 11:31 AM
CurlyDE
CurlyDE's Avatar
My vote would be one of these.
Kool ... you should go buy one so I can borrow it. I'm not a fan of the pickle fork ... I always end up tearing the boots.
Quick Reply: Tie-Rod Removal Tool
