EDIT: weak injector driver? other DME problems? PROBLEM FOUND!!!
Wondering if anyone here has experienced a weak injector output at idle, however once off of the idle switch (throttle switch) no problems exist? If so, how did you determine this?
Also, while on the topic of the DME has anyone experienced any other issues with the DME regarding idle performance/engine performance?
If you know anyone that is close and willing to let me try one out let me know. I am very close to shelling out the cash for a new dme but i am searching hard for proof first.
Dude youve made like 5 threads for one problem. Try making one thread. It would be easier to track your "Idle Problem" rather than 7 different causes to one possible problem
(I would also like to note that I personally do not have the time to read page long threads - so I do not expect that of anyone else)
Just jumped the fuel pump and dme at terminals 87, 87b and 30. Car ran richer upon initial startup and the voltmeter read slightly higher. Once warm the same symptoms existed. Once again verified this air to fuel ratios are steady off idle and at idle the air to fuel ratios are more steady cold than warm (seems to gradually get worse as vehicle heats up).
Opened the DME and found terminal t560 and what looked like a transistor literally partially burnt and broken. Traced this to the wiring diagram from clarks-garage and found it controls the idle stabilzer valve!!! NEW DME WILL BE ORDERED!!!
Way to solve your own problem! Glad you learned something!
944online and others sell rebuilds with warranties.
Or... might be worth identifying the bad component and soldering in a new one. Mouser no doubt has whatever component is bad. (Assuming something else on the board isn't destroying the bad component.)
I had found a short in the wiring harness near the connector of the ISV almost two years ago but it is fixed. The DME is not the one that originally went with this harness either so and has been opened numerous times for testing on other cars, etc. I know that every wire in my wiring harness has 0.2 ohms or less with clean connectors. I do not suspect any current problems that would cause another failure.
That is easy to repair. New part costs under one $. I did a post a bit ago with details. There are two drivers, replace them both. The question that needs to be answered is what caused that transistor to overheat. The wires under the intake tend to get hard and the insulation breaks, causing shorts. If you just replace the DME, it could look like your current one in just a couple of seconds.
https://rennlist.com/forums/showthre...ght=transistor
