Smoke under boost
just like the topic says, WHen I get into boost the car puts out some smoke out of the exhaust. I am running 16psi and my a/f's are between 11.7-12.2:1. At idle and around town driving there is no smoke at all. Maybe a leaky turbo? I guess I should do a compression test?
Ay ideas?
Ay ideas?
What's the color of the smoke? Is it a constant stream, or only initially when you stomp on the gas?
It's normal for a puff of black smoke to come out the back. However, it won't keep smoking. Leaky turbo could be plausible.
Once it boosts up it doesnt happen until full boost. Once in full boost it starts to smoke. Then its come and go. SOme times there will be steady smoke the whole time while at full bost and some times it will not be very noticable at all.
what color is burnign oil then? I guess the WB could be wrong? I will re-calibrate it then see.
My mods are:
turbo-s head that is extrude honed (original sized valves)
LR MAF
LR Mafterburner
LC-1 WB
3.0 bar FPR
Tial 38
custom cat-back 3" with no cats
55# injectors
My mods are:
LR MAF
LR Mafterburner
LC-1 WB
3.0 bar FPR
Tial 38
55# injectors
oops now I see it. You might check the O2 snesor as well as the plugs. Other things have been listed.
I have a similar set up on my car. I could not get the mixture right until I upgraded to the latest Lindsey chips and ran both the wideband and stock O2 sensor. The wideband by itself could not keep the mixture stable.
A wideband isn't supposed to keep a mixture stable...ever. That's not what it's for.
BTW: I also have 951max chips.
well here is anoher weird problem I have. When the stock O2 is plugge in, he car runs great around town, almost perfect 14.7:1 constant. Then I go WOT, it tapers to about 12-8-13.2:1 for like 4 or 5 seconds then gors strait down to 11.8 where its tuned to. SO I drive w/o a factory O2 and I still get great results whether putting around town or WOT.
or you could need the turbo resealed like i'm doing right now...cause it's spilling oil all over the intercooler and I had smoke...but it was more of a dirty brown/white mixture...puffs...
