Fuel Pump---does it run when key on?
Hello---installing a Mega Squirt---and would prefer to just do it a bit at a time.
So---does the fuel pump run when the key is on---or must there be a crank signal---or something else?
Many thanks,
Cy
Many thanks,
Cy
I am pretty sure it does prime when the key is turned on but only pumps for ? seconds then waits for the crank sensor to tell it the crank is turning. Anyone else verify?
