Lowest recommended spring in my tial 38
hally
How do you manage to run "only" 15 PSI with a 1 bar spring ?
I use a Tial 38 with 1 bar spring in single port mode and with the accuboost set at the softest setting I get no less than 17 PSI peak boost.
(Not that it bothers me as I run a 18 PSI set up)
Thom it touches 16psi then by redline its low 15s. Maybe when i've replaced the crumbling gasket where the wastegate connects, min boost might creep up a bit. That would be ok with me too
