Gas pedal really easy to push
Anyone know how to help or fix a gas pedal that you can push down with your finger. I don't know if a spring is missing or something else is wrong. I sometimes have to remove the floor mat because it will slide forward and push the pedal down.
Check the return spring at the throttle body and at the gas pedal. One of them may have broken.
You might be able to get a spring from the hardware store to help firm up the pedal a little.
I consider the extension spring as a added safety measure but even without it, my throttle still returned to idle fine and doesn't ever stick. It disconnected once and I didn't even notice until I happen to look under the hood.
You should have both springs working and either one alone should return the throttle to idle.
