Scratch on cylinder head mating surface, big deal or no..
Just wondering, i have a spare cylinder head that i will be sending off to Lindsey Racing for a rebuild and some other things. I noticed this on the #4 cylinder combustion chamber. Its a scratch, about 2 inches long and deep enough to catch a finger nail on. Will this cause any issues? The head is going to be decked and o-ringed anyway.. so im assuming no. But as usual i am the paranoid type
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201988%20Porsche%20944%20Turbo/IMG_5830.jpg)
What do you guys think?
well I would think Lindsey will do a better job than the last guy who appears to have used a feed rate too coarse and appears to have not clocked the mill head witch may make the surface concave .
only matters where the fire ring is in this case, you could scratch in a smiley face in the middle of each head where the gasket doesnt touch and you'd have one happy combustion chamber :-)
Hey, it is getting decked so i figure it will be machined out. Im just paranoid
It was machined once before and the witness marks are still visible. I decided to go o-ring and widefire gasket instead over the Cometic MLS. I just had fears about having to retorque the MLS and the fact theres no way to machine the block for flatness. I do plan to keep the cylinder head on my car right now, to eventually go with a MLS if i ever decide to rebuild another motor for the car.
Ill start a nice long picture full build thread once i get closer to doing the headgasket. I plan to start around March during my spring break. Right now im just amassing parts..
(the expensive part).
Herr Unmöglich
Like you don't even yet know Jon. We both come from the NA builds... when all is said and done, not too bad. But I think I have at least as much money into working on the 951 as the entire NA build cost including the car.
And it's still in parts all over the place.
I think you are smarter than me... you decided not to try to own both at the same time.
Anyhow the headwork is really whats killer, but again ultimate reliability is my goal with this car and i figure while i have it off..i should splurge a little. My long term goal is a reliable 300-325whp at mild boost, probably with the Vitesse Stage 3 setup. But for now, its all building everything up to support it. The 300whp should be enough to make me not want to bother with a 3.0L..or atleast be reliable enough for me to saving up enough to build the 3.0L
The only issue you may have is if the head was machined before how much material was removed? How much material needs to be removed now? You don't want to machine too much off the head.
Jon i know what you mean. Look what M758 said if you have to shave allot down then 1. either the head is no good or 2. need to go to a cometic and ask them for the thick one .4 something. I dunnno if widefire has thick head gaskets
