FS: 1989 European Turbo S
#31
At least it looks like it has M030 option stuff. All '89-'91 Euro models ddin't have them.
Sunroof models are more common in Europe than "sunroof-delete-models". Luckily i don't have sunroof in my '88 US spec car.
But ive got targa and rear wiper...
I could buy it if it wasn't in the us
#32
Former Vendor
The wheel caps are correct it just has the painted outline type on one side and the non-painted on the other, I actually didn't notice that.
It was optional but if you didn't have the option you have color matched covers to cap the holes. That's pretty neat, I didn't notice that either.
It's interesting having a couple hundred extra set of eyes to point things out.
#33
On the Radar
I have seen this car, and it is much better looking than the pictures show. I had considered buying it, but it was a little out of my price range. Wish I could have made it happen.
#34
Sunroof cars have a stiffer chassis than non sunroof cars
#35
EX could mean Japanise spec only exhaust temp warning system. VIN and option codes will tell if it was originally meant for Japanise market. Since its LHD there should be C08 option listed if its Japanise. In case of RHD model there would be C18.
#36
You may be correct. The ROW schematic shows the EX indicator ties into the Japan-only catalytic monitoring module. Car was probably a LHD Japan import.
#38
A 951 motor in good health running Motul 300V 15W50 usually shows an idle oil pressure (at full operating temp) hardly any lower than 4. But then perhaps the AC, front and rear demist were all three on when the pic was taken
We're not sure why this is but it can be adjusted and isn't necessarily related to collision damage. With that said the only cosmetic body repair we can find was done to the left front tip of the fender and it's worth noting that the car has had a full paint job.
#39
What comes to that "EX", i suppose Erkka is right.
#40
#41
Former Vendor
When running a low temperature thermostat I would expect "cooler" oil thus "stronger" oil pressure ?
A 951 motor in good health running Motul 300V 15W50 usually shows an idle oil pressure (at full operating temp) hardly any lower than 4. But then perhaps the AC, front and rear demist were all three on when the pic was taken![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The front left fender may have been taken off the car (perhaps replaced), and a poor refit would explain the wrong gap and the incorrect fender/bumper line up.
I don't mean to call you out on your oil pressure facts but the Porsche factory spec positive oil pressure does not reach four bar at operating temperature until 5000rpm. In fact, coming from a German shop who primarily works on Porsche vehicles the majority of which are 944 Turbos, we've never seen one get four bar idling at operating temperature even on fresh racing builds.
#43
The VIN only indicates it's an ROW car (not USA or CDN spec) for MY 1989. There is no Japan-specific VIN.
If it were a JP spec car then it would likely have option code 193 'Version for Japan'. If you post the option codes we may have a better idea.
#44
Best wishes for the sale, it sure looks like a nice car and examples with so little mileage are getting very rare.
#45
I do agree with Thom.
On my rebuilt engine, I see 4 bar at idle at full operating temperature with Motul 300 V 15w50. I only see a low 3 bar at idle in hot traffic hams when my A/C compressor (A big Sanden, not the stock Nippodenso) works. Before the rebuild, the pressure was 0.5-1 bar lower with the same oil.
