ngk bpr6es
ngk bpr6es
so the factory heat range for the spark plugs is bosch #7 which is equivalent to ngk #6 correct. i just bought some ngk bpr6es after all the recomendations on here but i just realized that everyone gets the bpr7es, or one heat range colder. for a daily driver k26/6 seeing a max of 16psi boost, would the bpr6es be ok for the winter, or should i run back to the store and gets the 7's?
