Question about 944online.com water pump kit
Hey all,
Just purchased an '86 951. Had my old man take a look at it, cut a deal, and now it's going on a boat and heading over here to Seoul.
I plan to replace the timing belt, water pump, when it gets here before I put more than a couple of miles on it just to be safe. I'm shopping around online; and so far it SEEMS that the best deal is the water pump/timing belt kit on 944online.com. Are these kits reputable? Do they have a history of failure? How about the difference between rebuilt and brand new? I understand the common sense thinking that brand new > rebuilt. But I'm more interested in solid, empirical data. Has anyone had any bad experiences with the rebuilds?
I'm sure this has already been addressed a couple times on the forum. But either i'm too tired or too stupid to enter the correct keywords that will unearth the information.
Thanks in advance.
Kyle
Thanks in advance.
Kyle
I have bought 2 of these kits for different 951s and they have been best value I could find, pretty much everything you need to get the whole job done. Go with a new pump though because I have heard bad things about them and the cost of one going out on you is not worth it. If I remember correctly the only thing that the kits did not come with was a thermost for the turbo water feed. It came with the main thermostat but I had to reuse the little one for the turbo water feed on the pump. They may have changed that or you may not need to replace but I figure while your in there you might as well.
Good kit though and Ian is great with support, if its hot where you live you can ask for a lower temp main thermostat and it will keep you running cooler in the summer
Ok, so it's a good kit. I should get the new pump. That sounds like a good plan to me. It gets really humid over here in the summer. I wouldn't say really hot though, not like arizona or southern california hot... more like alabama or georgia in august hot.
Thanks for the reply.
Kyle
Kyle
Well I am in Mississippi, and it gets pretty hot, but I put in a lower temp thermo and a lower temp fan switch and after about 5 minutes my 951 runs right at the first water temp mark for the rest of the drive no matter what, in 30-100 degree weather. It makes me happy
