Front Fender Removal ??
Hey guys,
I've had a pretty major dent in my drivers side fender for a while now, and I'm finally replacing it.
I took a quick look but can't seem to figure out how to remove the bolts where the fender meets the door.
I opened the door and checked in the obvious space where other cars have had the bolts but I couldn't see them.
Then I took out the "plastic" gaurd in the wheel wells and saw no holes or bolts where they were supposed to be. (used the replacment panel as a ref. )
Anyone know the easiest way to get to the bolts neer the door? ( I can take some pictures wed., becuause it almost looks like there's a sealent over the inside of the fender bolts in the wheel well !@#*&#@!*@???? )
Thanks in advanced
-Pieter
Thanks in advanced
-Pieter
The easiest way to do it is to put your socket on a long extension - then heat up the socket with a propane torch (it doesn't have to be TOO hot). Now you can just push the hot socket through the rubber goo and onto the head of the bolt!
