Power pullys .Are they worth it.??
Ive been looking at these for a while now , wondering if they are worth the money..
http://cgi.ebay.com/ebaymotors/ws/eB......340085&rd=1
Has anybody ever fitted a set + if so what were your findings..
What exactly do they do.??
The car im looking at fitting them too is a track prepped S2...
They run your auxiliaries at a lower speed so reduced losses. Slower alternator, power steering and ac. For track cars running at high RPM most of the time the slow running is just fine. For a street car charging, power steering and ac may be an issue when chugging around. I don't think they are legal in PCA stock.
I don't know the losses through the auxilliaries with the engine at 5-6K RPM maybe 10HP? Maybe underrunning saves 5hp?
The biggest gain is to ditch the power steering and AC. Some race cars run without an alternator and just a small batterry. That way you eliminate all the parasitic losses plus the weight of the equipment.
Now there are a set of lightweight pulleys and gears (BS and adj. cam gear) made by a guy, around $800 for a full set and have a dyno proven 13 hp gain. They also look great in black or red, he may have done a polished aluminum set as well.
What difference did it make to your car.??
Other than having some shiny bits of alloy on the end of your crank / auxilliaries.???
Or was it just that you had a "lighter wallet" at the end of it...???
My S2 doesnt have the AC, so its a start...
Ive heard + seen lots of stuff that looks good in principle, but does absolutely NOTHING to help the engine / car produce more usable power...So you could say , im a tad sceptical....
