Engine Harness Connector Identification HELP!
Alittle help required. I bought an 86 944 Turbo, and I bought it with the head off of it. Connectors disconnected with no idea where they when. Need some assistance identifiying connectors
Thanks!
1. ?
2. DME Connector
3. KLR Connector
4. ?
5. ?
6. KLR Manifold Vac Connector
1. Fuel Injector Connectors
2. TPS (Inserted)
3. AFM (Inserted)
4. Turbo Coolant Temp Sensor
5. ? (I know which sensor just don't know what it is)
6. Oil Pressure Connectors
7. Idle Control Valve (Inserted)
8. Knock Sensor Connector
9. Cycling Valve Connector
10. Ground Connectors on Back of Block and Bell Housing
11. Speed and Reference Sensor Connector
13. KLR Manifold Vac Source Connector
12. O2 Sensor Connector
13. KLR Vacuum Source on Intake Manifold
14. Two Connectors not show is the diagnostic port
Thanks!
1. ?
2. DME Connector
3. KLR Connector
4. ?
5. ?
2. TPS (Inserted)
3. AFM (Inserted)
4 goes to the turbo coolant temp sensor
5 goes the the temp sensor at the front of the head
6 goes on the oil pressure switch
9 goes to the wastegate control valve
10 goes the the bell housing small ground bolt
13 goes to the intake manifold banjo bolt
