S2 ring & pinion
Does switching the S2 R&P into a 951S transmission alter the final drive ratio or does it remain the same?
Cheers,
Keith
Cheers,
Keith
It certainly does. Makes it shorter. Unless you have uber hp it's a great conversion for most people I believe. The stock 951 'box is very long and sometimes hard to feel like you're in the right gear when going fast and slow. It will bring your top speed down a bit, but it's great around town and on most tracks unless very high speed ones, plus it's a stronger part.
Yeah, mine has it installed, and I knew that it was stronger, but didn't know about the ratio difference.
-So on my 951S the top speed has now come down, I suppose?
And I'm also assuming that the speedo over-reads a little also?
Keith
Keith
S2 R/P is stronger than the N/A and S. No matter what you hear, it is not stronger than a Turbo R/P. Take a look at the two sets side by side, and the 8/27 Turbo ring and pinion teeth are quite a bit larger than the the S2 8/31 - and when it comes to material strength, size does matter.
Speedo pickup senses the output shaft speed, so it will remain as accurate as it was with a Turbo R/P.
- It gives you 944 n/a gearing, but with a lower 5th gear than 83-87 US 944 n/a
- You could just barely hit 60 mph at the redline, instead of the 68 mph you should be able to hit with stock gearing, and top speed is reduced to 150 mph (which is faster than I have ever been on a track yet)
Yes I actually thought after I entered this info in at 4.00am, that in fact the S2 would not be stronger than the Turbo. It is stronger than the S cw&p as my mechanic confirmed this after destroying his one and going to the S2 version. Not sure about the size of the one in the 968 though, but it won't fit in our box's anyway...more as a comparison.
Oh, and if you're after something purely for 0-60mph, you won't get there in 2nd gear, just under.
S 2 ring and pinion ! ! ! WANT WANT WANT ! ! ! yep an S2 ring and pinion is on the acquisitions list. I have yet to talk to anyone who has done this who did not love it. Yes this is better for tight track, autocross and street apps and I think it will do me just fine in DEs. In addition I have heard that the top speed is closer to 160 than 150 HP depending. Still plenty damn fast.
IPSC
IPSC
My PO tended to only do sensible upgrades, and his (and my) mechanic assured me that they ARE most assuredly stronger than the turbo... His opinion seemed to be that the turbo S transmission -with its oil cooler and hardened 1st/2nd gears- would be better with the S2 R&P, so it was installed while the tranmission was dropped for a clutch change, if I understand correctly.
I wasn't sure about final drive ratio (hence the question), but 162MPH x 3.375 / 3.875 = 141MPH, so if the original top speed was limited by engine rev limit and not load factors, I'd expect the top speed with a 15% reduction in final drive to be rather closer to 140...
Certainly, 1st gear goes by VERY quickly!!!![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Keith
Keith
I bought a used S2 trans with the same idea in mind, to install the R&P in my spare 951S trans. When my wrench pulled the diff cover plate on the S2 trans it was ugly. Hardly any teeth left on the pinion shaft lol stock class i stay i guess
IPSC
IPSC
well as for strength I'm sure both parts are constructed very similar but you will generally be transferring less torque through your gearbox out put shaft and more torque through your half shafts. so you are less likely to break a gearbox part and more likely to break a half shaft than the 951
