UEGO 2000 WB02 Installation Help
Hello,
I'm installing a UEGO 2000 wideband that I bought used and it didn't come with any instructions. Does anyone have a wiring diagram for this? I'll be installing it with a PowerPerfect (and a Lindsey Racing St.II MAF), can they be wired together at all?
Thanks for any help you could offer.
Owain
Owain
Unless you have a piggyback to wire INTO the UEGO, for WBO2 readout on the laptop, the UEGO will be a standalone system. Sensor - get a bung installed about 16-18" down from the turbo down pipe, from the tri flange. The box can go numerous places and there are a couple of grommets to get stuff through the firewall and into the cabin.
Basically, you'll need a postive 12v switched and a good ground.
Yeah, that was what I was wondering, really. I assume the other wires are for communicating with the device in some way, to retrieve the logged data. Any idea how to do that? Can I connect it in some way to the Power Perfect?
Thanks,
Owain
Thanks,
Owain
Hopefully, the PO didnt cut any of the plugs off so it should be fairly simple. Depending on the version of the UEGO, you should have between 3 and 5 minutes of logging time in the display. Call LR early today, as I think they're only in the office for a 1/2 day, see if they can email you the instructions.
