Coolant leak
Coolant leak
So I have a pretty significant coolant leak that leaks when car is both on and off. After pulling off the belly pans and starting the car and letting it it run for a while the leak is coming from the drivers side and in about the middle of the engine bay. It is actually dripping onto the a/c hose that connects to the drivers side of the compressor b/c the coolant drips off of the bottom of that hose. What are the possible leak areas that I should look at? The leak is pretty significant, its either a fast drip or a thin, but constant stream upon shutdown. Turbo water pump maybe?
pull the jboot and intercooler pipe off the drivers side, and start squeezing hoses, they like to get realy mushy. It's a quick 5 minute dissadembly and makes it easier to spot issues. There are so many hoses there is no one place to start.
UAE Rennlist Ambassador
I had that sort of leak, right onto the compressor. The problem was with one of the hoses from the turbo pump to the metal coolant x-over.
The pump also could leak, some ppl here got an after market seal (after opening it and matching the seal) and worked fine, i couldn't and got a Mercedes Benz pump which worked fine. Look at the pump and it's connections.
hahaha. well anyway in my attempt to pull the j-boot off the turbo it just so happens to be completely fused to the turbo inlet. I guess thats what happens if it hasnt been pulled off on 21 years. are there any tips/tricks to pull it off; i really dont want to pull the intake mani off.
