Looks hot! Make sure to upgrade to 968 caster blocks on the front control arms, if you haven't already. Otherwise those big wheels will blow out the stock bushings in no time.
Thanks Luis having it aligned today I will mention that.
No at install used 3mm spacers on the front for center cap clearance then trimed them slightly but wheels/tires are fine no rubbing ABS warning etc. Running 18 x 10 285/30 rears and 18x8 225/40 fronts.
Originally Posted by odb812
any issues with clearance on the dust caps? spacers? your car looks really nice.
