green vac line from heater valve
Should I put that to the vac. canister near the battery? If it belongs there , where would I hook up the line coming from the firewall?
thanks
mike
thanks
mike
No.
The heater valve line goes one of the firewall ports.
The remaining firewall port goes to a vac tee.
Second port of this tee goes to vac accumulator.
3rd port of this tee goes to the one-way valve which comes off of the brake booster vacuum line.
This one way valve ensures that there is only vac supplied to the heat controller and accumulator.
If you were to apply boost - the system reverts to fail safe , which is HEEEEEEAAAAAAAT.
