Brey Krause Harness Guide Bar - Advice needed please!?!
I'm looking at fitting a set of 5 point harnesses and have been looking at the Brey Krause Harness Guide Bar: http://www.bkauto.com/porsche/r1020.php but am a little confused as to how it fits and also where you mount the harnesses to in the rear as obviously this is only a guide bar?
Does anybody have the Brey Krause kit and does anybody know of a better alternative. I will even consider a half cage if this is a better solution ...
... Any pics and prices paid would be evn better - Many thanks, Mark
P.S. the cheapest I can find this for is £300.00 from Porscheshop.co.uk which I think is a bit on the costly side.
The harnesses attach to the rear seatbelt points and loop over the guide bar.
The best solution is the Redline Rennsport rollbar. The problem however is it will be cost prohibitive to get one overseas to the UK.
I have one of these for sale in the classifieds. It's a really nice piece for routing your harness. It attaches at the upper mount for the shoulder harnesses for the main bar and has two stainless steel extensions with heim joints that attach at the upper mount in the sail panel where the upper mount is for the rear shoulder harness. They have small loops welded on four places where the harness goes through to keep them from moving side to side. Since this is a gude bar, your belts need to attach to the factory belt mounts via a harness supplied with bolt on mounts.
