Cam tower gasket oil leak
Old 10-13-2007, 05:58 AM
rop3
rop3's Avatar
Default Cam tower gasket oil leak
Are there any write ups or photo's on this anyone knows of?
Old 10-13-2007, 10:43 AM
nynor
nynor's Avatar
what is it you are looking for? pictures of the leak? how to fix it? is yours leaking? are you talking the gasket that interfaces with the head or the rear gasket?
Old 10-13-2007, 11:12 AM
philcav7
philcav7's Avatar
clarks garage has the "how to"
I believe 944online has a blown up schematic of the cam tower and gaskets.
The rear cork gasket is prone to leaking and is an easy 30 minute replacement, the tough part is squeezing the wrench back there.
The head to tower gasket is another story, which requires much more effort.
This gasket started weeping on my after a run of synthetic oil, I was able to cure the leak by slightly loosening and re-torqueing the bolts.
Quick Reply: Cam tower gasket oil leak
