connecting rod bolt set
I am re-using the 951 rods for my rebuild but need to replace the rod nuts and bolts as directed. All I can find are the raceware replacement kits however I am trying to go a more economical route if possible. Are there other rod nut and bolt kits out there and where?? Thanks.
Quit Smokin'
I was always under the impression that when using stock bottom end parts you only had to replace the rod nuts, not the bolts? Can someone correct me here, or comment?
I wish you were right but apparently the rod bolts are made to stretch when torqued and "should be replaced". I just placed an order for a set of the arp through ebsracing... very nice, very helpful people..and close to me too.
