Just switched to Valvoline high mileage 10-40 synthetic blend
On miles...
On recommendations for current models...
Your 18-20 year old car does NOT have the specs, clearances, cooling, oil passage design, or technology of the current models. Just think of leaded gasoline. Was an additive put back in to replace lead or were new motors designed and changed to work without lead? So why is it again that you would follow recommendations made for a newer motor?
2¢
2¢
There is alot of misinformation and BS about fully synthetics and the majority of it originates from the early days of synthetic oils where there may have been issues and problems. Time and technology has moved on in the last 20yrs in relation to fully synthetic oils and this hype is no longer valid. I'd struggle to understand why anyone would not use fully synthetic oil on any car - turbo or N/A. I'm not an advocate of using thicker oils to fix oil leaks - if my engine leaks i'll fix the leak.
Mobil 1 is a very good oil, no doubt about it. But there are plenty of much much better oils out there. Mobil 1 is not the only oil that Porsche recommends, in fact it recommends quite a few, it's just the one manufacturer that pays Porsche big bucks to use it on the production line and on services. Thre is an association with Mobil 1 and F1 and i'm continually amazed at the number of poeple who think that Mobil 1 you buy off the shelf is the same stuff they use in F1, but in reality it relates in no way to the stuff they use in F1. Clever marketing.
I only ever use an Ester based fully synthetic oil. Mobil 1 is not an Ester based oil.
Also regarding leaded gasoline. Cars that run off unleaded have ceramic or hardened valve seats so they don't need the lead or a lead replacement additive. For a motor that was built pre-unleaded you can either have the cylinder head modified or you will need to use a lead replacement additive.
http://www.joegibbsracingoil.com/datasheets/81106.php
