replacement relays for Rennbay light kit?
I just tried to get onto Rennbay's site and could not checkout, however I was looking for a higher quality replacement relay for the headlight kit they sell anyway. The relays that came with the kit have already failed. Has anyone else experienced this? Does anyone know where to find a higher quality replacement 5-pin 30/40 amp relay with mounting tab?
Thanks!
Thanks!
You can get them on Ebay
Or go down to your local NAPA and ask for a standard automotive relay.
Or look up some upgraded solid state relays
They have a standard pin configuration so you can replace them with hundreds of options. The reason why we went with standard and not the solid state ones is that not everyone wants to tack on an extra $85 to the kit. As long as they are in the 30/40 amp range, what ever you choose will work just fine with the kit. If you need help or want to know if a relay you find online will work with the kit specifically just shoot me over a pm with the link.
what happened when your relay failed?? For some reason my headlights are on coming up but they only stay on for a second or so then shut off. Could this be the relay?
Sounds more like a grounding issue. The high beams are on a separate relays so see if those stay on. If not then check the grounding strap off of the harness.
