How do you know if the idle stabilization valve is bad?
The car (1986 951) was idling very rough so decided to change all the vacuum lines this weekend.
I am in the middle of replacing all the vacuum lines and I find the cycling valve has a broken port.
Now am thinking as long as I have to replace the cycling valve should how do I know the idle stabilization valve (ISV) does not need to be replaced as well.
Is there anyway to test the ISV with the everything disassembled? It would be a real pain to get everything put back together then find out I have to replace the ISV.
Not sure on the MBC, have not made that mod yet. But on most vehicles, Ive found that if you can shake the Idle control valve/motor, and it rattles, it's normaly bad.
One thing you can do is try bypassing at the engine diagnostic test socket it to see if the idle changes for the better. You can do this with a pair of needle nosed pliers, inserting one tip in each of the 2 ports that must be bridged for the bypass to occur (search for "setting the idle").
In my case, when I pulled it off the car, I tested it by capping one port with my thumb and blowing through the other only to find that it leaked air.
Probably could've tried sealing it with RTV as it was expensive to replace, but with the new unit the idle is back to normal and I can forget about it for another 15 years.
