The chips are mapped for .95 bar - I would not use an MBC with these chips. Use the banjo bolt, if your needle hits the two bar line, you need to drill out the jet a little bit with the supplied drill bits. It should hit the line just before 2.
Hmmm...this brings up a new problem. New chips are a little outta the price range right now...is it really that bad of an idea? I can use the MBC so set it to .95 bar... Am I making a mistake?
