I just ordered the .027 Cometic head gasket..
Will reducing the thickness make that much of a difference. Keep in mind the head will get shaved and trued no more than .005 . Thanks
If you have stock valve train the valve to piston clearance with .005 head shave and a .027 headgasket is going to be very small. One little incident of over revving or botched shift and you may be getting the tops of your pistons indented.
I would stick with the factory .043" IIRC thickness.
