Broken red-white wire/power window circuit ?
Anyone have this before ? Pass window inop. I checked from both switches to the each harness at the bend point of the harness and no problem there. It must be from each door to door insided the car. Are there any junction blocks, if so , are they on both sides of the car ? If not then I will just run a seperate wire under the dash to each door harness ? Thanks
