Greddy e-01 EBC
Old 08-29-2007 | 11:02 AM
DrZ1's Avatar
DrZ1
Default Greddy e-01 EBC
Anyone using this EBC. I will be hopefully installing this weekend and curious if any tips on install.
Steve
Old 08-29-2007 | 12:49 PM
reno808's Avatar
reno808
I have the older ebc blitz. It should be the same install from my understanding. If it is then i can help. What kind of "wastegate" do you have?????????????
Old 08-29-2007 | 01:01 PM
badcoupe's Avatar
badcoupe
I use the e-01 I used manual setup with my DP gate helpful for logging info as well. I have rpm and wb02 hooked to it.
Old 08-29-2007 | 04:17 PM
DrZ1's Avatar
DrZ1
I was curious about this, did you try the auto learn mode. Rather then manuel set up??
Also, what wideband, I purchased the innovate and have ext signal harness to tie into the e-01, can you log rpm and A/F at the same time?
Any trouble installing?
Quick Reply: Greddy e-01 EBC
