I had 4 stage IV turbos from huntley. All 4 were different and even came from different companies. Your best bet is to send it to a reputable turbo place such as Majestic and have them check it out for wear and see what exactly it is.
does any one have a compressor map for huntleys "stage 5" turbo. It is a turbonetics / KKK hybrid unit.
Im trying to see of it will fit my 3.0L project..
thanks
There's no possible way anyone can know from that general description. It's real simple to take the housings off. I'd recommend doing so and mic'ing the wheels to see what size inducer/exducer (large side/small side) of both the compressor and turbine. Once you have those numbers, then you can start to figure out what size turbo you have. If you can get the inducer/exducer measurements, I can probably find out for you.
