Microencapsulated Knock Sensor Bolt?
The FSM says to install the knock sensor with a new 'microencapsulated" bolt. The bolt I removed is standard enough in size, but shows the remains of blue goo -- "microencapsulation" material presumably. Anyone have the part number for said bolt? PET is not clear to me on this and the regular 944 stores don't seem to stock it. Thanks.
Hey Man
http://solutions.3m.com/wps/portal/3...r/Scotch-Grip/
Hey Man
Wonder why they didn't specify loctite?
You can always buy a 3M 'microencapsulated' coating and do your own but it seems sort of pointless to me.
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
UAE Rennlist Ambassador
When i removed the sensor to re-wire the terminals, i re-used the bolt without washer as the manual stated, no problems, no loctite as well.
I believe this is because they want the bolt to receive all the 'noise' and go straight to the sensor, and not have a washer interfere with it?
3m, 944, 944s, 964, bolt, bolts, encapsulated, installing, knock, locktite, micro, microencapsulated, microencapsulation, porsche, sealant, sensor, thread
