Longer Lasting Timing Belts
Originally Posted by KuHL 951
As easy as belt changes are I can see replacing one on a car with no records. Then you have the same people that change the water pump with every belt...go figure?
So would you rather do two belts on the 944 or the single belt on your iX? BMW sure didn't make a belt change much fun on those either if you've done yours. I prefer the 944 only because I've done a few, my 325iX had me swearing at whoever designed those metal belt covers, distributor cap, a forward hinged hood, and studded standoff bolts.
1988 325ix - Diamantschwarz. Sold at 275,000mi. in perfect running order but the body was starting to lose it's fight with cancer (man, I miss that car). The biggest mistake of my life was selling that car, the second biggest was breaking up with the girl I sold it to.
1989 325ix - 4dr AT, Silver. Bought on Ebay, sold 2 years later as it wasn't nearly as fun as the 2dr loaded MT '88.
Hey Man
Originally Posted by eniac
I owned a couple 325iX's as well. One of which was for 8 years so I had my share of pain changing that belt a few times. I always removed the hood and the radiator(the skin on my knuckles was thankful for that). So yeah the 944 belts are WAY easier to change. lol
You can now return to the usual timing belt hysteria.
This pic is from the day I bought it two years ago and before cleaning it up, new wheels, and new Lexan fogs.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Don’t worry about your belts – worry about the rollers / tensioners.
Belts don’t fail without reason – its usually bad rollers / tensioners / water pump.
One point nobody has brought up. Belt life changes drastically with expose to contaminants particularily oil based.
oil, grime, dirt, etc will directly effect belt life and premature failure.
You people are freaking belt ****'s. A quality belt like a Gates or Conti will go the full 30K and then some. People are worrying about a 4 year old 4K mile belt? Retension your belts and you'll see more than 30K. The 944 isn't kind to critical belts but I think many people overreact about Belt Zen...it's still just a car and you need to keep it running well.
Since we're on the topic of belts, can they get stretched easily? I was doing mine last weekend and didn't bother looking up what tension to go to with the Kricket, so following the directions that come with it I tensioned the cam belt to 100 and the Bs belt to 70 or so. By the time I figured out I have them twice as tight as they are supposed to be, I didn't have time to undo the tensioners before leaving for vacation. Will the belts be screwed up from sitting over-tensioned for two weeks? I also hand cranked the motor a couple of times, but I doubt that did any damage.
Also, are new balance shaft belt idler pulleys grey in color, or are they black? I'm fairly certain I put the new pulley on instead of the old, but just wanted to check.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Please stop me if you have heard this before…..
Its not the belts – it’s the rollers / tensioners!!
By over tightening (and leaving it that way) you are adding a lot more stress to the bearings of the rollers/tensioners. When they fail so will you belt and your engine.
So, at the risk of being redundant - Its not the belts – it’s the rollers / tensioners!!
Well another reason for timing belts going is the balance shaft belt going and taking out the timing belt with it. People tend to forget about the balance shaft belt because it doesnt have as stringent replacement interval and in threory it fails safe, but in reality there is a high chance it will take out your timing belt. Just replace it ahead of the Porsche recommended service interval and only change your balance shaft belt and there is nothing to worry about.
