View Poll Results: Can a k26/6 hold 15psi at the redline?
Voters: 84. You may not vote on this poll
#47
What wastegate are you using? I'm guessing something along the lines of a lindsey club gate?? I would guess something just short of an act of God would make a stock wastegate perform like that.
#49
Monkeys Removed by Request
#50
my lindsey dual port held 15psi to redline.
I would be much more surprised to read that your K26-6 / dual port gate with manual boost controler spooled to 15psi peak at 3,x00 RPM and held 15psi flat to redline with no spikes and no drops.
It seems like a good EBC is your friend here.
I am actually pretty surprised that 944cs's car behaves the way his data shows. IIRC even the factory manual says that the car won't work that well with all factory parts. I know the chips are different, but its still pretty amazing that the stock wastegate is working that well.
#51
old thread
My update - => Last September running at Bonneville I was surprised to find at the top of fifth no matter my ebc settings boost would fall off to about 12psi
possible due to altitude, possible due to failing seal in turbo.
#52
#53
I can not get mine to hold 15psi from 3000 rpm to 6500. No matter what I do, or where I set the boost, I always loose 3 psi by redline. If I set it to 18, I will have 15 at redline. I have a k26/8, shimmed wastegate, and a manual boost controller. Maybe if you have a good EBC, you've got a chance. My turbo was in excellent shape when I installed it, and my motor was fresh.
#54
I think the thread starters questions were more of people loosing more than 3psi by redline. I.E. guys going from 16psi to 11psi that sort of thing.
a 26/6 can hold 15psi to redline. You just need a healthy engine and turbo. Which I had both.
#56
#57
I was in the same boat. I'd loose 3psi by redline. But, I always ran 18-19psi.
a 26/6 can hold 15psi to redline. You just need a healthy engine and turbo. Wish I had both.
