Help: High Vibration at idle
86 951 bought with 45k mile currently 58k (one owner car)
I did a bunch long term maintenance since I bought the car 12 months ago:
New trimming belt and rollers
New water pump
New motor mounts
Replaced most of the gaskets in the exhaust system to fix multiple leaks
New plugs
New wires
New distributor cap and rotor
New fuel filter
New Pads
New Rotors
Changed brake fluid
It pulls strong, no oil smoke, almost zero oil consumption but there is one problem.
Lots of vibration at idle. The idle speed is correct and stable. As RPM increases the vibration is less but it can still be felt when driving. There does not appear to be any misfire and all the plugs looked good when I changed them.
Any ideas on what to look for are appreciated.
New water pump
New motor mounts
New plugs
New wires
New fuel filter
New Pads
New Rotors
Changed brake fluid
If you pulled the balance sprokets to change the seals, you probably flipped your balance shafts. I did it the first time i did the belt and rollers and it shook like crazy.
read here
clarks-garage.com/shop-manual/eng-08.htm
to see what im talking about, very easy to forget.
read here
The balance shaft sprokets are the gears on which the belt spins. Each one has a notch on the back side of it. These notches are supposed to line up to marks on the timing cover. Clark's garage offers a great explanation...I have pics, but not with me now. Will upload later if possible.
Motor Mounts can cause this too. Once had a brand new one that was defective and caused significant vibrations at idle. Scratched the head for a while because you wouldn't have thought a brand new mount would be failing.
is it vibrating at all rpms?
check the above but I had some bad vibration up to about 3K rpm or so and it eventually turned out to be mucked up injectors....
sometimes it seemed better than others...
Good luck JC
Good luck JC
Yea its not hard to check the alignment of these guys while in the car I just had a better shot because mine is out right now. The top is super easy and if you have trouble with the bottom for some reason, just grab a handheld bathroom mirror and put it down there to get a better look.
get some white touch up paint. paint the indent on both the gear and cover, bottom paint the line and the indent on the gear.
put the car on TDC and check the upper BS gear. The notch on the back of the gear should line up with the indent on the back cover.
I'm just asking, please don't be offended, you did double check TDC when you put the timing belt on and you do you have the wires in the correct order?
but I would take the sprockets off as well to make sure they are even on there correctly. I had mine flipped 180 and it lined up perfectly with the belt covers but the actual shaft was 180 wrong
